Re: IH 606 3-point hitch
Posted by Hugh MacKay on June 04, 2003 at 18:32:17 from (64.228.14.97):
In Reply to: IH 606 3-point hitch posted by Bill C on June 03, 2003 at 12:50:40:
Bill: I wish you had a picture of that hitch to post. I have never seen a 606, however I'm thinking that hitch should be same design as other 04 and 06 tractors. Both those vertical lift links should be the same. They should both have levelling cranks. I'm not just sure what you mean by Y type. The ones I remember had about 1" pin going through rockshaft with a hole on the end at right angles to pin. The levelling crank and lift link attached in that hole on head of bolt. I am not sure this will make sence to you as it's hard finding the right words to put on it. One place where a picture would be worth a 1000 words. Come back with your comments, I'm sure we can sort this out.
Post A Followup
: Re: Re: IH 606 3-point hitch
