Farmall Tractors Discussion Board
Re: H tractor --- McCormick No. 1 blade
Posted by Harold H on September 19, 1999 at 09:00:06 from (207.244.7.53):
In Reply to: H tractor --- McCormick No. 1 blade posted by MJD on September 19, 1999 at 00:45:12:
Mike,
There were slight differences in the 39 and 40 and 41 H's. The early hood was different as was the starter switch and instrument cluster. There was also a slight difference in the clutch housing casting. I think the grille was also a little different. The controls were also slightly different. Some of these changes were made during 40 and some during 41. The horsepower did not change. It was tested in Nebraska test number 333 (gasoline) at 26.20 belt hp and 24.17 db hp with 3603 max lbs pull at 2.06 mph. The #1 fast hitch rear blade was all red I am pretty sure.
Harold H
Post a Followup
: Re: Re: H tractor --- McCormick No. 1 blade
