Re: HM wide front
Posted by Dewa on June 04, 2003 at 22:54:12 from (4.36.1.175):
In Reply to: HM wide front posted by D.J.Kristoff on June 04, 2003 at 19:28:16:
D.J. I am currently putting a swartz wide front end (steering arms in the back, or under the tractor), that came off of a Super MTA, onto a Super "H". The bracket that bolts to the bolster (4 bolts), fit perfectly. The steering plate holes as Will said, have to be changed. I mig welded all four holes completely shut, buffed the weld off flush with the plate surface, remeasured for the new hole locations, and then drilled the new holes at 4 inches on center in both directions. As for the stay rod bracket that Red Rider mentioned, he's right, it is to wide to bolt up to the "H" frame, but there is plenty of room to drill new holes in the same bracket to be able to bolt it to the frame. Just move the back two holes forward on the bracket until they come in line with the center of the tractor frame. The front two holes will simply move closer together on the bar stock that runs crossways. You will also at this point, most likely have to drill new holes in the tractor frame. Then once you have it bolted on, there will be some excess material sticking out past the frame on either side of the tractor. You can either leave it there, or to make the job look real nice, take a torch or plasma cutter and trim off the excess flush with the tractor frame. Hope this helps, Dewa
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
