Re: Does anyone make Piston Rings for a 3 bore Far
Posted by klf on June 05, 2003 at 19:44:07 from (12.45.21.88):
In Reply to: Does anyone make Piston Rings for a 3 bore Farmall posted by Mr. J on June 05, 2003 at 14:54:46:
You can get them from value built too. (Had to spell it this way so that it would post).
Post A Followup
: Re: Re: Does anyone make Piston Rings for a 3 bore Far
