Re: Super oil drain
Posted by rustyfarmall on June 07, 2003 at 09:05:57 from (216.248.75.188):
In Reply to: Super oil drain posted by Roger on June 07, 2003 at 08:38:35:
No, you are not missing anything, it is not lefthanded threads, it is simply rusted in, you will have to remove the oil pan, clean all of the oil out of it, and then heat the area around the plug with a torch, grab the plug with a pair of vise-grips, and it should come out.
Post A Followup
: Re: Re: Super oil drain
