Re: Super oil drain
Posted by Brian on June 07, 2003 at 15:31:56 from (65.49.176.204):
In Reply to: Super oil drain posted by Roger on June 07, 2003 at 08:38:35:
There should be no problem with clearance. However, bring a couple of different sized extensions for you ratchet. Make sure you don't over tighten the two end bolt ( bad experience ), if you stip them your into a whole other game. I think the expression goes.... it's earier to tighten then to replace threads. You might need a wrench for the front bolts.
My 2 cents.
Post A Followup
: Re: Re: Super oil drain
