Re: Does anyone make Piston Rings for a 3 bore Far
Posted by scotc on June 07, 2003 at 18:03:04 from (162.39.3.61):
In Reply to: Does anyone make Piston Rings for a 3 bore Farmall posted by Mr. J on June 05, 2003 at 14:54:46:
check with any engine shop, they should be able to file them down, just take in your block and rings, they may even set em in for you, not a hi-po engine builder left (i'll eat those words i'm sure) that doesnt custom-file their rings
Post A Followup
: Re: Re: Does anyone make Piston Rings for a 3 bore Far
