Posted by Red Mist on March 29, 2009 at 20:40:17 from (67.142.130.36):
In Reply to: idle screw useless posted by karl f on March 29, 2009 at 11:29:55:
karl f said: Also, if you partially remove idle mixture screw, the tractor all of a sudden will idle fast. But, if you completely remove screw it will die.
The idle mixture screw on these carbs is an air (rather than fuel) adjustment. So, if you open the screw it is acting correctly when it starts idling faster - since it is getting leaner. Similarly, if you completely remove it, it would die, since it would be completely leaned out. So, I'd say the idle screw was behaving correctly.
Are you turning the screw 1/4 turn at the time while giving it a few seconds to adjust to each 1/4 turn? That is important when fine tuning.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
