Re: Farmall H Steering
Posted by Schneider on June 08, 2003 at 15:59:59 from (198.164.97.142):
In Reply to: Farmall H Steering posted by Doug on June 07, 2003 at 16:01:47:
Doug,
Had the same problem with my 52 H at road speed front end wobbled and shook terrible. I put new tires on,changed air pressure, checked u joints and asked a lot of questions, got alot of good advise but in the end my problem was in the worm gear in the front. The worm gear part was not worn but where the center of the worm gear slides down over the splined shaft on the front was worn bad. I used brass shim stock around the shaft. It didn't take it totally away but about 90%of it.
Post A Followup
: Re: Re: Farmall H Steering
