Re: Re: 1468 / V8
Posted by Clint Proeschel on June 08, 2003 at 20:20:36 from (209.251.25.139):
In Reply to: Re: 1468 / V8 posted by K.B. on June 07, 2003 at 17:22:41:
We had a 1468 on our farm back in the 70's and it sadly was the last farmall my grandfather bought. He bought a JD 4630, and on the same day, same field, same plow, the 4630 would plow a gear higher, and one MPH faster. The difference is in the engine design. Gas, or Diesel, you can't beat the torque of an inline motor vs. a V-design. If you remember, the ford 300" inline 6 had more torque than the 302" V-8. Now, lets talk about a Cummins-equipped Dodge, vs. a Chevy Duramax, or a Ford Powerstroke. In stock trim, the ford and chevy have more hp and tq, but when you start adding fuel, look out!! The cummins gains torque so much easier/quicker than the V-8's it isn't even funny...
Post A Followup
: Re: Re: Re: 1468 / V8
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
