Re: Water in Rear Tire
Posted by Randy in NE on June 09, 2003 at 04:14:23 from (216.58.237.20):
In Reply to: Water in Rear Tire posted by Peabody on June 08, 2003 at 19:40:28:
As far as the Super C is concerned it doesn't really care one way or the other. A couple of things if you are planning on pulling with it. You will have uneven weight distribution when you haul it on a trailer. Bad if the heavier side is the right side (ditch side). If you want to pull it then you would probably want to take the water out so that you can get down to a lower weight class. Wheel weights or any other kind of steel weights would be preferable. That way you can more easily add or remove weight. Not that 145 pound weights are the easiest things to throw around.
Post A Followup
: Re: Re: Water in Rear Tire
