Re: What models wide front will fit a IH 666
Posted by Aces on June 09, 2003 at 12:46:24 from (67.0.17.28):
In Reply to: What models wide front will fit a IH 666 posted by GP on June 09, 2003 at 10:30:29:
the 666 is the only 66 series you can change the front ends on unless they can with a narrow front from the factury and most can with wide because wide was standard by then. But a 06 56 will fit, this has been talked about many times before, the 565 666 had smaller wheel bearings than the bigger tractors 560 706 806 etc had biger bearings. So they will bolt on but you may need hubs and bearings.
Post A Followup
: Re: Re: What models wide front will fit a IH 666
