Re: What models wide front will fit a IH 666
Posted by K.B. on June 09, 2003 at 16:47:32 from (209.163.30.82):
In Reply to: What models wide front will fit a IH 666 posted by GP on June 09, 2003 at 10:30:29:
The front end from the rest of the 66 series tractors will not work. The 06, 26, 56 series row-crop wide front end will bolt right up. 544 Row-Crop and 686 also have that front end. Like Ace said in the post below, you may need different wheel bearings and hubs if the front end you buy came off of somthing big.
Post A Followup
: Re: Re: What models wide front will fit a IH 666
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
