Re: F 12 valves
Posted by F14 on June 10, 2003 at 17:13:48 from (204.181.143.156):
In Reply to: F 12 valves posted by Shank on June 10, 2003 at 12:00:35:
The book says .013 Hot.
Procedure is same as for any valve train, adjust each tappet when the cam lobe for that valve is on the base, the valve is fully closed, and the tappet is loose.
You can adjust several valves from one position (either intake or exhaust) but I don't remember the sequence, and it's not in the book. Perhaps someone will post it.
Post A Followup
: Re: Re: F 12 valves
