Re: oil change
Posted by CNKS on June 10, 2003 at 19:48:27 from (207.178.96.212):
In Reply to: oil change posted by brent on June 09, 2003 at 20:12:19:
Crankcase holds 5 quarts. Trans case holds 4.5 qts, add 1 more qt if it has belt pulley and pto. Rear axle drives hold 3 pt each. Use 90W or 85W-140 in the trans and final drives. Hytran will leak more and cause excessive gear clash when shifting. 30 weight oil in engine, 15W-40 if you live in a cold climate and want a year-round oil. You said it was an A, not a Super. If it is a Super, use Hytran in the hydraulics.
Post A Followup
: Re: Re: oil change
