Re: M. Diesel won't start on gas
Posted by Haas on June 11, 2003 at 04:36:17 from (12.65.61.77):
In Reply to: M. Diesel won't start on gas posted by Marc on June 10, 2003 at 19:41:23:
You must have the levers in correct position for gas operation. That is the switch over lever forward and the diesel speed control all the way down in shut off. With the lever in gas postion, the magneto switch is opened to unground the magneto so a spark can be delivered, the float in the carburetor is released so gas can flow, butterflys in the manifold are set so air flows through the carburetor and the third valves in each cylinder are opened to reduce the compression for gas operation. In diesel mode the mag is grounded so no spark is delivered, the butterflys are set so air does not flow through the carb, the carb float is locked up and the valves to chambers in head are closed so you get diesel compression. The switch for the magneto is located in a chamber at the front end of the manifold. There should be a wire going from the magneto ground connection to the manifold chamber. Also check your plug wires, the rotor and points in the magneto. The magneto rotates COUNTER clockwise(IH gas engine magneto and dist rotate clockwise) so if you installed the wires for clockwise rotation it won't start. Also, the points cam has only two lobes with a 2 to 1 gear between the cam and the rotor, so the distributor can get 180 degrees out of time. To correct that remove the cover over the points chamber and turn the rotor 1/2 revolution and put it back. If the incorrect timing (180 degrees out or the wires installed wrong) you will be getting backfires and it will blow back through the air cleaner. Air cleaner oil will be blown out of the intake.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
