Re: Clutch replacement on Cub LoBoy
Posted by Sharky on June 11, 2003 at 05:55:13 from (199.196.144.11):
In Reply to: Clutch replacement on Cub LoBoy posted by IH Since Birth on June 10, 2003 at 17:33:12:
Very simple, Be sure to have a pilot tool, or some other way to align the spindle to through the clutch plate as it is made of thin spring steel and can be broken in not aligned properly when putting the two halves back together, also go the Carter & Gruenwald and buy the throwout bearing that is the true bearing (not the graphite one like the original), Check the fingers on the pressure plate also, very common to break these off, Might as well replace the pressure plate too, it's not that expensive and will save you from having to do it again.....
Post A Followup
: Re: Re: Clutch replacement on Cub LoBoy
