Re: Farmall A: Adjusting Points
Posted by Aces on June 12, 2003 at 08:09:09 from (67.0.38.132):
In Reply to: Farmall A: Adjusting Points posted by NS Farmer on June 12, 2003 at 06:18:00:
When you have the rotor and inner cover plate out you will see that the shaft has four lobs. rotate shaft until one lob is contacting the point lob that is where you set the point gap any one of the four will do. That cut out should line up with one lob.
Post A Followup
: Re: Re: Farmall A: Adjusting Points
