Re: A Farmall\screwy generator
Posted by Bob M on June 12, 2003 at 09:24:27 from (165.170.128.66):
In Reply to: A Farmall\screwy generator posted by Terry on June 12, 2003 at 08:13:53:
Terry - I gotta agree with the others! Sounds like you took your voltage readings with a DVM - it's responding to the background "hash" from commutator switching. Bet if you stick an analog DC meter across the battery you'll see a rock-steady 6-1/2 to 7 volts or so.
Long ago I learned that old tractor electricals are often best analyzed using equally ancient instruments. I have an ancient Simpson VOM (salvaged from a scrap barrel at work) for this kind of stuff. It sees more use around old tractors, etc than does the Fluke 87 that also lives in my toolbox...
Post A Followup
: Re: Re: A Farmall\screwy generator
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
