Re: Re: Farmall C timing adjustment
Posted by dan on June 12, 2003 at 17:05:29 from (63.185.72.236):
In Reply to: Re: Farmall C timing adjustment posted by Hugh MacKay on June 12, 2003 at 14:04:20:
You should be able to see it if you get no 1 up on the compression stroke and look on the flywheel. It will probably be a line with DC 1-4 on it. The pointer is STAMPED into the front lower bellhousing coverand kinda hard to miss. Some of them I have to take some sandpaper to the flywheel to find the mark. Wire brush works too.
Post A Followup
: Re: Re: Re: Farmall C timing adjustment
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
