Re: Removing reluctant flywheel on F-30
Posted by dlp on June 12, 2003 at 19:13:07 from (130.184.114.35):
In Reply to: Removing reluctant flywheel on F-30 posted by Okla/kans bill on June 11, 2003 at 11:12:00:
You say it is moving, that is interesting. The flywheel is on a taper & if it moves ever so slightly, it will fall off. Are you trying to pull it with the taper pin still in it? If you put pressure on the pin (as with a puller), & try pulling the flywheel, it should jump in your lap when it breaks its seat. I ran 3 pieces of allthread in the 5/8" threaded holes & then bumped each one with a impact while I had "pulling" pressure on the pin.
Post A Followup
: Re: Re: Removing reluctant flywheel on F-30
