Farmall Tractors Discussion Board
Re: Farmall Cub starting problem
Posted by Mike F on September 20, 1999 at 06:33:08 from (209.240.200.204):
In Reply to: Farmall Cub starting problem posted by John Schnaubelt on September 14, 1999 at 19:52:34:
Try putting some type of heat under the carb. I put a coleman lantern under the carb (sit it on the floor under the carb) It works wonders in really cold weather. Please be carefull with the lantern around the fuel! The heat helps the updraft carb vaporize the fuel.
GOOD LUCK
Post a Followup
: Re: Re: Farmall Cub starting problem
