Farmall Tractors Discussion Board
Re: Case 1030
Posted by Farm-Al on September 20, 1999 at 07:11:05 from (205.188.198.48):
In Reply to: Case 1030 posted by RPV on September 20, 1999 at 06:17:13:
RPV.... I had A 1030 Case it was an old work horse. They were built from about 1966 until about 1969. The bad side; the brakes were mechanical and for a tractor this size not adequate, the brake and clutch pedals on the older ones lacked the mechanical advantage, this they redesigened on the later ones. The 1030 came out with the 1000RPM PTO, the only way to go to 540 was to change the gears in the PTO gear housing using 930 gears & shaft. It was rated at around 105 HP.
Post a Followup
: Re: Re: Case 1030
