Re: Farmall SC Light Switch Wiring
Posted by Randy in NE on June 13, 2003 at 11:37:22 from (216.58.237.20):
In Reply to: Farmall SC Light Switch Wiring posted by C. Amick on June 13, 2003 at 10:55:07:
I have a rough diagrahm in the parts manual for my C. If you have the battery removed and you are looking towards the the rear of the tractor: A wire goes from the fuse holder to the post in the upper right hand corner of the light switch. The post in the upper left hand corner goes to the head lights. The post in the lower part of the switch is for the rear lights. There should also be a resistor for high/low beam located on the left hand side of the switch. All of these right/lefts are assuming that you are facing the rear of the tractor and you are looking at the back side of the switch. I would try scanning this and e-mailing to you but it is pretty tough figuring out what all of the wires are for and I have the parts list to cross-check with. Hope this helps.
Post A Followup
: Re: Re: Farmall SC Light Switch Wiring
