Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Hugh MacKa
Posted by RN on June 14, 2003 at 20:24:50 from (166.126.218.251):
In Reply to: Re: Re: Re: Re: Re: Re: Re: Re: Re: Hugh MacKay an posted by Diana on June 14, 2003 at 20:14:02:
Heater helps at 80 even. Last year tried morning starting without heat a couple times, second attempt with heat usually worked. Tractor sent to shop shortly after- $1000.00 deposit, told fix it. Injector clean, fuel pump refurbished, 2 low compression cylinders fixed. Starts/works good now. RN
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Hugh MacKa
