Re: injector pump question
Posted by Haas on June 15, 2003 at 17:31:52 from (12.65.36.59):
In Reply to: injector pump question posted by Jack on June 15, 2003 at 14:32:34:
The filler tube is for putting oil in the pump. The petcock is to check the oil level. The other plug lower down is to drain the oil when you change it. As David said, oil should be changed in injector pump whenever you change engine oil. If you are getting diesel out the petcock, the pump has a bad seal.
Post A Followup
: Re: Re: injector pump question
