Re: Re: ID'ing a Farmall
Posted by Charles on June 15, 2003 at 18:50:09 from (65.81.139.125):
In Reply to: Re: ID'ing a Farmall posted by K.B. on June 15, 2003 at 18:00:50:
I'll try to answer as best I can:
1. I believe utility. It will only clear about 30" or so.
2. Front end is straight--at least if you mean the angle of the axles to the body of the tractor
3. Gearshift is like this:
R 2 4
1 3 5
4. Decals and emblems are confusing. The center to the steering wheel says Case. The back of the seat says IH. The guy I got it from had painted it Walmart red with spray paint. I don't believe there are any decals on it.
5. I am afraid I don't know enought to ID the injection pump. Heck, I can't even find where to fill it with hydraulic fluid. :-)
6. I'll have to go out when it is light and look at the tires. I recollect the number 14.9 on them. Is that any help?
7. It definitely has glow plugs.
Thanks so much for any help you can give. As you can tell, I am a newbie at this.
Post A Followup
: Re: Re: Re: ID'ing a Farmall
