Farmall Tractors Discussion Board
Re: Re: H FARMALL
Posted by Geezer Mn on September 20, 1999 at 14:16:31 from (216.161.105.6):
In Reply to: Re: H FARMALL posted by The Red on September 19, 1999 at 08:31:19:
Knock out exp. plugs under shifter bonnet.push out pin (about7/16 x 2 1/2). Pull out lever.Jack up one side rear wheel.To release binding of gears.Use flashlite to see in to trans.With large screwdriver push shifter rails for or aft.2 rails will be out of place.line up 3 slots left to right. the slots are as wide as shifter end.When jacked wheel is free you are in neutral.Repair lever end and pins. Or you will get real good at this.
Post a Followup
: Re: Re: Re: H FARMALL
