Re: plugs on hydra touch valve-HELP PLEASE!!!!!!!!
Posted by KX on June 16, 2003 at 12:03:59 from (38.115.0.254):
In Reply to: plugs on hydra touch valve-HELP PLEASE!!!!!!!!!!!! posted by big red 1 on June 16, 2003 at 05:06:54:
No reverse threads but that could be hard to get out. Just be patient and don't damage the threads on the valve body. Try to turn it out with a cold chisel inside the broken off piece first, hit it in several places rather lightly then increase power of the blows but keep rotating the chisel around till it starts turning. Watch and make sure you aren't cutting through the nipple into the valve body threads. That is what I would try first anyway.....best of luck.
Post A Followup
: Re: Re: plugs on hydra touch valve-HELP PLEASE!!!!!!!!
