Re: Re: Need a grille gaurd for a 1206!
Posted by KX on June 16, 2003 at 12:11:27 from (38.115.0.254):
In Reply to: Re: Need a grille gaurd for a 1206! posted by K.B. on June 15, 2003 at 18:04:30:
No the 06 and 56 series do not latch the same way or have interchangeable grills. I have 806 and a 856, the 806 has the spring that latches the big heavy cast grill in place, the 856 has a tubular grill that is much lighter, sits on two pins at the bottom with two spring pins at the top.
Post A Followup
: Re: Re: Re: Need a grille gaurd for a 1206!
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
