Re: Super A engine continues to fire after shutti
Posted by Ben in KY on June 16, 2003 at 19:36:06 from (207.246.76.73):
In Reply to: Super A engine continues to fire after shutting o posted by Jon on June 16, 2003 at 19:27:31:
I believe the high compression pistions caused the problem ie. dieseling. I am not sure of a soloution though.
Post A Followup
: Re: Re: Super A engine continues to fire after shutti
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
