Re: Super C noise in the transmission....
Posted by Hugh MacKay on June 17, 2003 at 02:33:41 from (216.208.58.159):
In Reply to: Super C noise in the transmission.... posted by Jesse on June 16, 2003 at 17:05:57:
Jesse: Any noise such as this from clutch would be associated with clutch slipping, and you haven't mentioned that. Are you absolutely sure clutch is not slipping? If you are mowing with a bush hog I suspect any clutch problem would hit sooner than 2 hours.
The next place I would look is brakes. Your tractor is a Super so disc brakes and those require cleaning from time to time. You could also have some broken springs in brakes.
I wuld check those two out first as transmission noises usually don't go away.
Post A Followup
: Re: Re: Super C noise in the transmission....
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
