Re: 560 WITH BELT PULLEY
Posted by Hugh MacKay on June 17, 2003 at 03:22:40 from (209.226.247.23):
In Reply to: 560 WITH BELT PULLEY posted by Dave L on June 16, 2003 at 10:00:46:
Dave: I guess we are all assuming you are refering to side mount pulley as oposed to PTO mount. I think the only ones you can even consider are MTA, 400 and 450. I never had a pulley on my 560, however the plate you remove to install a pulley is full width of tractor chassis and that is probably 2-3 inches wider than chassis of 300, 350 or 460. I had a 300 with a pulley at same time, 300 is quite small through chassis compared to the larger chassis.
Post A Followup
: Re: Re: 560 WITH BELT PULLEY
