Re: Super A engine continues to fire after shutti
Posted by Bob M on June 17, 2003 at 04:50:47 from (165.170.128.66):
In Reply to: Super A engine continues to fire after shutting o posted by Jon on June 16, 2003 at 19:27:31:
Running on is pretty much normal in your situation. Attibute it to the combination of high compression pistons and the poor quality nolead gas sold today. A few things that can help: Adjust the carb idle mix just a bit rich (1/8 turn) from ideal. Set the idle RPM as low as possible. Idle motor for a minute or two at low idle before hitting the kill switch. Run higher octane (premium) gas instead of regular. (Note - changing ignition timing does NOT affect running on, since by definition the ignition is off when it occurs). If all else fails, put the tractor in high gear and partially engage the clutch as you hit the kill switch. That'll stop the motor instantly!
Home
| Forums
Today's Featured Article -
Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
