Re: Super C motor oil
Posted by RayP(MI) on June 17, 2003 at 17:30:39 from (216.46.196.165):
In Reply to: Super C motor oil posted by John on June 17, 2003 at 13:42:32:
You really should consider removing oil pan, cleaning out dirt which has undoubtly accumulated there, and check oil pump intake screen while you're in there. Then go with your choice of oil, changing regularly, and filter too. I use 40 weight (detergent)in mine in hot weather, as there's quite a bit of blow-by as evidenced by oil on hood around crankcase breather.
Post A Followup
: Re: Re: Super C motor oil
