Re: H clutch repair question.
Posted by Michael Soldan on June 19, 2003 at 17:25:31 from (216.46.130.14):
In Reply to: H clutch repair question. posted by Kelly C on June 19, 2003 at 14:33:19:
Kelly , Aces is correct and here's some finer details. With the liftall removed you take apart the drive shaft, this is obvious when you get at it. There are 6 bolts holding the clutch, remove three and put them into the holes provided for compressing the clutch springs,(every other one) then remove the other three and the clutch will drop, turn sideways and come out the bottom. Two things to remember when you put it back together are that the convex side of the clutch shaft joining ring must face the clutch. Put the clutch shaft in before removing the three capscrews that you used to compress the clutch spings. Once you get on your back and see up into the belly you will get the drift of it. Good luck from Mike in Exeter Ontario
Post A Followup
: Re: Re: H clutch repair question.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
