Re: Re: Trailering Questions
Posted by rustyfarmall on June 20, 2003 at 04:59:18 from (216.248.75.179):
In Reply to: Re: Trailering Questions posted by Careful with a clevis... on June 19, 2003 at 19:23:16:
If you get the rear chain good and tight, and I mean tight, and fasten down the front of the tractor from either side like has been described, that tractor will not move.
When tightening those load binders, you need to actually get them tight enough that you are squashing down the tires, you may need to use a cheater bar on the binder in order to accomplish this, and you will need to stop and check the tightness after a couple of miles or so, it will loosen up somewhat. I have hauled many tractors using this method, and have never had one even offer to move around on the trailer.
Post A Followup
: Re: Re: Re: Trailering Questions
