Re: 560 Pto clutch type -drain and fill Help!!!!!!
Posted by Jimmy King on June 21, 2003 at 13:30:49 from (207.222.148.124):
In Reply to: 560 Pto clutch type -drain and fill Help!!!!!!!!!! posted by big red 1 on June 21, 2003 at 12:15:13:
I have a 460 and the PTO oils from rear end hyd oil, drain plug is to drain it if you work on it or when you change oil. I have owned it since early 1970's only times oil has been changed was when I had to go into trans or rear end to work on it. Believe for many years it had the tar worked out of it. was my round baler tractor for many years plus haybine 7ft. offset plow ect.
Post A Followup
: Re: Re: 560 Pto clutch type -drain and fill Help!!!!!!
