Re: Re: Re: H needs a little help......
Posted by Ken on June 21, 2003 at 20:31:08 from (67.200.32.122):
In Reply to: Re: Re: H needs a little help...... posted by Bob on June 21, 2003 at 10:46:00:
Bob it sounds like you have a generator, not an alternator if it had a 6 volt battery. As far as I know in my 60+ years I have never seen a 6 volt alternator. When alternators first came on cars and tractors in the early 1960's, all cars, trucks and tractors had 12 volt batterys, which were negative ground, by that time. Your H had a 6 volt, positive ground battery and GERERATOR. I changed my H to a 12 volt alternator from a 1987 chevy and replaced the hand push button and swithch with a key switch and solenoid. (Because of playful grandchildren, I can remove the key) It's the best starting tractor I have ever seen! If you need more info on changing your H to 12 volts, let me know and I will e-mail you all the info you will need.
Post A Followup
: Re: Re: Re: Re: H needs a little help......
