Re: Removing Rear Wheels
Posted by David Saville on June 21, 2003 at 21:57:56 from (142.165.111.210):
In Reply to: Removing Rear Wheels posted by Bill on June 21, 2003 at 17:08:44:
I took the axles and wheels as a unit to a
machine shop from a WD 9 once. He put the
wheel in his press and took it up to maximum
pressure. Then he heated the wheel. When it
finally popped the whole shop moved. It
would only go an eigth of an inch at a time.
I was also told that when the tractor would still
run they would take the retainer off and then
turn tight circles while jamming on the inside
brake to break them loose. The guy telling me
claimed to have spent a long time making
circles before some of them let go.
Post A Followup
: Re: Re: Removing Rear Wheels
