Farmall Tractors Discussion Board
cub overheating
Posted by scott on September 21, 1999 at 04:42:23 from (206.193.125.71):
i just recently replaced the radiator in my 52 farmall cub, and changed the oil and filter as well. i had not used the cub very much before that for awhile, but now the cub is overheating and my oil pressure drops after i drive it about .5 miles. the new radiator has no leaks in it, and at startup and idle, the oil pressure is good. the more i drive it, the lower the pressure gets, and i had steam coming out of the relief tube. when i shut it down, i can hear the gurgles around the engine and radiator when it is cooling down. does anyone have any info on what could be the problem with the thermo-siphon system? thanks
Post a Followup
: Re: cub overheating
