Re: Re: Re: 560 Pto clutch type -drain and fill He
Posted by Red Man on June 22, 2003 at 12:33:10 from (65.239.169.190):
In Reply to: Re: Re: 560 Pto clutch type -drain and fill Help!! posted by don Severson on June 21, 2003 at 19:56:23:
The PTO on these tractors does NOT get it's oil from the rear-end. They hold about 2qts. of Hy-trans fluid. Fill to the level plug on the side of the unit, pour through the fill plug on top of the unit.
Post A Followup
: Re: Re: Re: Re: 560 Pto clutch type -drain and fill He
