Re: MD stuck in 4th gear
Posted by Hugh MacKay on June 22, 2003 at 17:23:07 from (64.228.11.149):
In Reply to: MD stuck in 4th gear posted by Jesse Morris on June 22, 2003 at 09:48:07:
Jesse: When you remove lever as Alton has suggested, and then line the rails up. The end of you shift lever should be built up with weld until it just nicely fills the notch on one rail. The finished lever should have a rectangle shaped end very slightly rounded on corners. I like to get these just a bit over size and grind until it shifts smoothly. It takes a little time and patience. If you don't build it up it will just do the same again. If you happen to be shifting on the move and it stays in 4th and also goes into 3rd and you happen to drop clutch out, you will most certainly do damage. I had this happen once, result 4 gears with broken teeth and one bent shsft. Don't fool around with this.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
