Re: Farmall H Radiator drain plug cap
Posted by Farmer Bob on June 22, 2003 at 20:02:17 from (64.113.13.203):
In Reply to: Farmall H Radiator drain plug cap posted by John on June 22, 2003 at 19:04:51:
The drain pipe is standard 1/2" iron pipe and the new repro cap you received should fit. Try a new 1/2" iron pipe nipple with good treads on both ends. Originals stuck down through the bolster far enough to get the cap on and off. You can also try some teflon tape on the treads.
Post A Followup
: Re: Re: Farmall H Radiator drain plug cap
