Re: Thermosyphon cooling questions
Posted by Randy in NE on June 23, 2003 at 04:01:16 from (216.58.237.20):
In Reply to: Thermosyphon cooling questions posted by Will on June 22, 2003 at 23:20:00:
You may want to consider flushing the radiator and block. If you have a lot of crud built up inside the motor and some of the passages are either blocked or have reduced flow this can cause the tractor to run hotter than necessary. Scale/rust build up on the surfaces will reduce the heat transfer capabilities.
Post A Followup
: Re: Re: Thermosyphon cooling questions
