Re: Thermosyphon cooling questions
Posted by Haas on June 23, 2003 at 05:54:13 from (12.65.74.46):
In Reply to: Thermosyphon cooling questions posted by Will on June 22, 2003 at 23:20:00:
As the others said, no need to add a water pump as long as things are well maintained. But, you need to make sure the radiator and the block are as clean as you can get them. If you want to flush it, take both top and bottom hoses loose and stick a water hose in the top neck of the connection to the engine and run water through. You'll get rust and crud out. Also run water through the radiator. Also, you need to check the coolant level frequently to make sure it is at the proper level per the operators manual. If you are doing heavy work and you let the level get low, you can burn some valves. First to go will be number 4 cylinder, because it is at the back end and gets the least cooling.
Post A Followup
: Re: Re: Thermosyphon cooling questions
