Farmall Tractors Discussion Board
Re: H FARMALL
Posted by Mark on September 21, 1999 at 08:02:49 from (12.28.201.185):
In Reply to: H FARMALL posted by SAM DEAN on September 19, 1999 at 08:21:04:
I had the same problem (a couple times) pulled the shifeter out and aligned the forks to neutral. Got sick of doing that and had to pull the cover and repair the broken fork guide (bolted to cover). Good Luck!
Post a Followup
: Re: Re: H FARMALL
