Re: Re: Re: Super A Oil Change- I want the final a
Posted by Doug in OR on June 23, 2003 at 14:22:51 from (12.225.51.197):
In Reply to: Re: Re: Super A Oil Change- I want the final answe posted by Dave_Id on June 23, 2003 at 13:18:37:
The company I work for uses 15W-40 in everything they run. Even the Fords where they recommend 5W-20. To tell the truth, they all start using oil at the 50 to 70K mark. This includes a Ranger that is assigned to only me - and I drive it like I do my personal vehicles. I use 5W-30 in my personal vehicles and they never use oil.. even past the 200K mark. That 15W-40 oil looks like maple syrup even on a 40 degree morning. It just can't be good for a new, tight engine on a cold morning.
New oils don't have viscosity shear problems like the old oils did. You don't need the extra thickness for the oil to hold up. You lose cold weather pumpability with the thick stuff. Personally, my philosophy is one of "thinner is better" - at least in a mechanically sound engine.
Post A Followup
: Re: Re: Re: Re: Super A Oil Change- I want the final a
