Re: Re: Re: 1944 Farmall A PTO Problem
Posted by Roger on June 24, 2003 at 19:09:32 from (69.58.144.66):
In Reply to: Re: Re: 1944 Farmall A PTO Problem posted by LarryE on June 24, 2003 at 18:14:54:
Larry, If the transmission is warm, it can spin for quite a while before it stops spinning causing grinding. Also, if you don't have enough transmission fluid in the transmission it will also keep spinning. The drain plug is on the bottom of the main transmission casting on the right rear side. It is a plug with an internal square hole. The filler plug is by the shifting lever. The full plug is on the left side of the front of the transmission. Fill until it comes out the hole on the full plug. According to my manual, the transmission holds 5 quarts of transmission fluid. Roger
Post A Followup
: Re: Re: Re: Re: 1944 Farmall A PTO Problem
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
