Re: help on an ih truch with hoist problems
Posted by Bob on June 27, 2003 at 07:57:41 from (66.163.134.177):
In Reply to: help on an ih truch with hoist problems posted by chad on June 27, 2003 at 06:58:20:
1. Tank too full of oil or too small for the application.
2. Is it a POWER DOWN (DOUBLE ACTING) hoist? If it is, you must run the truck PTO while lowering the hoist, or the backside of the hoist cylinder will not be filled with oil, and the tank will overflow with the excess oil.
3. Wrong oil. (Some types of engine oil will froth and foam when used in hydraulics).
4. Clogged tank breather, or has to small of a vent hole.
Post A Followup
: Re: Re: help on an ih truch with hoist problems
